19 years agoFFT/IFFT Unity Gain Example
Here is an example that I did a while back when I was playing with the FFT/IFFT core. It was built with DSP Builder 6.1. Also it incorporates the unity gain formula highlighted in the Block floating ...
17 years agoHi, all!
Finally got around to upgrading my FFT/IFFT Unity Gain Example to version 8.0. This version is slightly different: 1. It seems like the FIFO behaves a little bit differently in version 8.0 (either it's always been like this and I haven't noticed it before, or the behavior changed in the 7.1 re-write). The FIFO has one cycle latency, after the assertion of read request flag, before it would output the correct data. To compensate for that effect, I had to delay the ifft_out_exp before adding it to the FIFO'ed fft_out_exp. Also to compensate for that delay, I also had to delay ifft_out_real and ifft_out_imag. 2. It seems like I was only passing 16 bit of data into the FFT core before. Therefore, I changed the input processing module a little bit... Now you can specify how many bits to use for your cosine wave inputs. Notice that if you use the whole 18 bits (as the FFT/IFFT cores), then your ifft_out_imag stays zero (unlike before). Notice that if you use less bits for the input, then you would get some noise in your ifft_out_imag. (This is probably due to the inexact rounding/truncating after each stage of butterfly -> an artifact of the block floating point format that the streaming FFT is using)... I have attached the updated model (.zip file) and also the updated screen shot (.jpg file). To use the .zip file... do the following: - Unzip the .zip file into your working directory. - In your working directory, create a DSPBuilder_myTest_import subfolder - Place the two .vhd files (the top level wrapper files for the FFT and IFFT module). - Open up myTest.mdl and regenerate the two IP cores. Enjoy!
