19 years agoFFT/IFFT Unity Gain Example
Here is an example that I did a while back when I was playing with the FFT/IFFT core. It was built with DSP Builder 6.1. Also it incorporates the unity gain formula highlighted in the Block floating ...
18 years agoHi,
Sorry for the delay in response. I just saw this posting today... It shouldn't be a big deal... probably some sort of rounding error due to fixed point representation... If you look at it... the dynamic range for image out is merely from 4 to -4. But the dynamic range for your real out is from 10^4 to -10^4ish area... therefore it's practically insignificant and I would not worry about it... Hope this helps...
