19 years agoFFT/IFFT Unity Gain Example
Here is an example that I did a while back when I was playing with the FFT/IFFT core. It was built with DSP Builder 6.1. Also it incorporates the unity gain formula highlighted in the Block floating ...
18 years agoHi,
I'm trying to repeat your FFT scaling Matlab testbench simulation using DSP Builder and FFT megacore version 7.0 and I think the simulation results are not quite right. I'm attaching the display results of the initial_real/initial_imag and final_real/final_imag. If you can give some idea how to fix the problems, it will be helpful. Thanks, Regards, wimax
