19 years agoFFT/IFFT Unity Gain Example
Here is an example that I did a while back when I was playing with the FFT/IFFT core. It was built with DSP Builder 6.1. Also it incorporates the unity gain formula highlighted in the Block floating ...
18 years agoHi, Wimax,
I am sorry, but I no longer have access to the 7.0 version of DSP Builder (I have moved onto the newer version). But perhaps if you can describe what you are doing, I might be able to help. I am guessing whatever you are seeing should correspond to what you are building. You can simply run a quick test with the generated FFT matlab model if you want. Regards, -wronghorizon
