17 years agoFFT 8.0, sink_ready de-asserted
I am trying to test the functionality of FFT version 8.0. The device family that I am using is Cyclone II. Below is the parameter of the FFT: Transform Length: 64 points Data Precision: 8 bits Twiddle Precision: 8 bits I/O Data Flow: Streaming Structure: 4 Mults/2Adders Implement Multipliers in: DSP Blocks/Logic Cells Twiddle ROM Distribution 100% M4K As for the FFT input, I wrote a FSM code for it. My input looks fine, sink_sop, sink_eop and sink_valid are where it is suppose to be. However sink_ready was asserted at the beginning, one clock cycle before sink_valid and sink_sop were asserted. Then sink_ready was de-asserted half way before sink_eop (before 64 data ends). As a result, source_error shows “11”; meaning that EOP is asserted before 64 valid samples are accepted. Since I am using streaming architecture, I thought this architecture allows continuous processing of input data and outputs a continuous complex data stream. So that means the sink_ready was suppose to be asserted all the time isn’t it? Unlike in buffered burst and burst architecture, sink_ready signal will be de-asserted when FIFO is filled. So why for streaming architecture in my case, the sink_ready can be de-asserted causing it unable to accept data? Does anyone know this answer?33 Replies
the sink_ready signal shouldn't be deasserted. can you post screenshots of your simulation?
--- Quote Start --- the sink_ready signal shouldn't be deasserted. can you post screenshots of your simulation? --- Quote End --- Hi, Thanks thepancake for your reply. Here is it. Does had to do with my input? The input should be fixed point complex number right? If my input is -97- j97 and I set the radix as signed decimal, is it wrong? - Altera_Forum
--- Quote Start --- Hi, Thanks thepancake for your reply. Here is it. Does had to do with my input? The input should be fixed point complex number right? If my input is -97- j97 and I set the radix as signed decimal, is it wrong? --- Quote End --- Sorry, image seems small. I attach again here. - Altera_Forum
what does the input clock look like? is it running at the same speed as the imaginary data is changing, or the real data?
leaving source_ready asserted all the time is legal but i don't think it will solve your problem. i simulated an FFT core with your settings in Quartus 8.0 SP1 using Altera's testbench and i got the expected results. - Altera_Forum
--- Quote Start --- what does the input clock look like? is it running at the same speed as the imaginary data is changing, or the real data? leaving source_ready asserted all the time is legal but i don't think it will solve your problem. i simulated an FFT core with your settings in Quartus 8.0 SP1 using Altera's testbench and i got the expected results. --- Quote End --- Hi, Thanks thepancake. I zoom in the image closer so you can see. - Altera_Forum
ok your clock looks right.
try asserting reset_n? - Altera_Forum
--- Quote Start --- ok your clock looks right. try asserting reset_n? --- Quote End --- Yup, the reset_n was asserted. - Altera_Forum
in both of your pictures reset_n has not been asserted (set to '0'), right?
Nope. For both picture both reset_n was set high. If reset_n was set (0) the sink_ready will be (0).
i understand that, but you should try asserting reset_n for the first few clocks of your simulation.
