17 years agoFFT 8.0, sink_ready de-asserted
Hi, I am trying to test the functionality of FFT version 8.0. The device family that I am using is Cyclone II. Below is the parameter of the FFT: Transform Length: 64 points Data Preci...
17 years ago --- Quote Start --- what does the input clock look like? is it running at the same speed as the imaginary data is changing, or the real data? leaving source_ready asserted all the time is legal but i don't think it will solve your problem. i simulated an FFT core with your settings in Quartus 8.0 SP1 using Altera's testbench and i got the expected results. --- Quote End --- Hi, Thanks thepancake. I zoom in the image closer so you can see.
