17 years agoFFT 8.0, sink_ready de-asserted
Hi, I am trying to test the functionality of FFT version 8.0. The device family that I am using is Cyclone II. Below is the parameter of the FFT: Transform Length: 64 points Data Preci...
17 years ago --- Quote Start --- the sink_ready signal shouldn't be deasserted. can you post screenshots of your simulation? --- Quote End --- Hi, Thanks thepancake for your reply. Here is it. Does had to do with my input? The input should be fixed point complex number right? If my input is -97- j97 and I set the radix as signed decimal, is it wrong?
