Ethernet IP core
Dose anybody knows if it possible to implement Ethernet communication (10/100 MHz) on FPGA (lets say Cyclone 3…)? Is there any Altera proven VHDL IP core for that? (I don’t what to write the TCP IP/ UDP code- I only need the interface with the Ethernet). Is there any Evaluation board that recommended for that purpose? Thanks, Idan7 Replies
--- Quote Start --- Dose anybody knows if it possible to implement Ethernet communication (10/100 MHz) on FPGA (lets say Cyclone 3…)? --- Quote End --- Yes. --- Quote Start --- Is there any Altera proven VHDL IP core for that? (I don’t what to write the TCP IP/ UDP code- I only need the interface with the Ethernet). --- Quote End --- Yes. Triple Speed Ethernet MAC. --- Quote Start --- Is there any Evaluation board that recommended for that purpose? --- Quote End --- Any Altera development kit with Ethernet. - Altera_Forum
check this, it could be helpful for you
http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar - Altera_Forum
If you only need 10/100 and not the 1Gbit feature, you can use the OperCores MAC as an alternative to TSE. This way you don't need to buy a TSE licence.
oh!. I'm also doing a thesis about this topic. I'm trying interface between Cyclone III's Ethernet and PC through a cable. I can help me if you will show your code and i can see it.
And i'm also see a problem about it. I dont know how to set up IP for Cyclone III's Ethernet. and this is my code: "module altera_eth_addr_swapper ( clk, reset_n, avalon_st_rx_data, avalon_st_rx_empty, avalon_st_rx_eop, avalon_st_rx_error, avalon_st_rx_ready, avalon_st_rx_sop, avalon_st_rx_valid, avalon_st_tx_data, avalon_st_tx_empty, avalon_st_tx_eop, avalon_st_tx_error, avalon_st_tx_ready, avalon_st_tx_sop, avalon_st_tx_valid ); input clk; input reset_n; input[63:0] avalon_st_rx_data; input[2:0] avalon_st_rx_empty; input avalon_st_rx_eop; input[5:0] avalon_st_rx_error; output avalon_st_rx_ready; input avalon_st_rx_sop; input avalon_st_rx_valid; output [63:0] avalon_st_tx_data; output [2:0] avalon_st_tx_empty; output avalon_st_tx_eop; output avalon_st_tx_error; input avalon_st_tx_ready; output avalon_st_tx_sop; output avalon_st_tx_valid; reg [63:0] pipeline_data; reg [2:0] pipeline_empty; reg pipeline_eop; reg pipeline_error; reg pipeline_sop; reg pipeline_valid; wire [63:0] avalon_st_tx_data; wire [2:0] avalon_st_tx_empty; wire avalon_st_tx_eop; wire avalon_st_tx_error; wire avalon_st_rx_ready; wire avalon_st_tx_sop; wire avalon_st_tx_valid; always @(posedge clk or negedge reset_n) begin if (!reset_n) begin pipeline_data <= {63{1'b0}}; pipeline_empty <= {3{1'b0}}; pipeline_eop <= 1'b0; pipeline_error <= 1'b0; pipeline_sop <= 1'b0; pipeline_valid <= 1'b0; end else begin if (pipeline_sop & pipeline_valid) begin pipeline_data <= {pipeline_data[47:16],avalon_st_rx_data[31:0]}; end else begin pipeline_data <= avalon_st_rx_data; end pipeline_empty <= avalon_st_rx_empty; pipeline_eop <= avalon_st_rx_eop; pipeline_error <= |avalon_st_rx_error; pipeline_sop <= avalon_st_rx_sop; pipeline_valid <= avalon_st_rx_valid; end end // Output assign avalon_st_tx_data = (pipeline_sop & pipeline_valid)? {pipeline_data[15:0], avalon_st_rx_data[63:32],pipeline_data[63:48]} : pipeline_data; assign avalon_st_tx_empty = pipeline_empty; assign avalon_st_tx_eop = pipeline_eop; assign avalon_st_tx_error = pipeline_error; assign avalon_st_tx_sop = pipeline_sop; assign avalon_st_tx_valid = pipeline_valid; // Backpressure is not supported assign avalon_st_rx_ready = avalon_st_tx_ready; endmodule " - Altera_Forum
The Avalon-ST interconnect to the TSE MAC is 32bit wide. Also the data is transfered when SOP is low, since SOP flag is only asserted on the first 32bit of data.
I found out a document for your problem. Look at at "network_utilities.h" it defined IP_address.
Good luck! - Altera_Forum
In VHDL language, To define an IP_address is really very difficult. But instead of you must have written by C language as I've already said for you.
best wishes!
