17 years agoErrors building Clocked Video Output
I added a Clocked Video output to a design and feed it with a scatter-gather DMA. There are two Avalon ST adapters in the path to make it work.
I'm getting a bunch of errors like this: "Error: IP Generator Error: Unable to set generic "USE_EMBEDDED_SYNCS" on entity "alt_vip_itc"- the parameter cannot be found on the entity" I'm attaching a screenshot of the Quartus errors below. The design is based on the Cyclone III starter kit example from the nioswiki. It contains a CPU, SSRAM, SDRAM, flash and the SGDMA/CVO thing I added, no other video blocks. Thanks, Andrew
