17 years agoErrors building Clocked Video Output
I added a Clocked Video output to a design and feed it with a scatter-gather DMA. There are two Avalon ST adapters in the path to make it work. I'm getting a bunch of errors like this: "...
13 years agoAphraton,
In your case you will need to write a custom HDL block. The reason for this is that the SGDMA does not know anything about the VIP protocol. Your pipeline might look something like: Clocked Video Input -> VIP to streaming converter -> SGDMA -> PCIe Compiler ( PCIe Hard IP ) PCIe Compiler ( PCIe Hard IP ) -> SGDMA -> streaming to VIP converter ->Clocked Video Output The streaming to VIP converter will need to generate VIP control packets that describe the format of the video, and then pass through the video data with appropriate start of packet and end of packet bits. I think you also need to convert from ready latency 0 to ready latency 1 (for VIP). The VIP to streaming converter will need to do the reverse of what I described above. You may also want to use a frame buffer before your clocked video output if for any reason the SGDMA block cannot output the data fast enough to keep the clocked video output's internal FIFOs from starving.
