F-Tile xcvr placement on DK-DEV-AGF023FA
I have an Agilex 7 FPGA F-Series Development Kit 2xF-Tile DK-DEV-AGF023F. I have 1 F-Tile working with PCIe Gen4x16, and want to use the second for 400Gb Ethernet.
I have used the F-Tile channel placement tool, which results in a valid placement. See attached.
I have been plagued with placer message such as the following.
Error(22811): The specified block ftile_eth|u0|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_rx cannot be placed at the location fgt_q2_ch0_rx as the block requires stream(s) [0] in an Ethernet 400g block but the location only supports stream(s) [7, 11, 13, 14].
I have swapped bit orders and other trials, and they all lead to a similar error. Given the placement of the QSFPDD on the board, I need to used FGT Quads 2 and 3
I have also tried to use the 100G-4 F-Tile configuration, which move the FGT usage to Quad 1. And I result it the following error:
Error(22811): The specified block ftile_eth|u0|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_rx cannot be placed at the location fgt_q2_ch0_rx as the block requires stream(s) [0] in an Ethernet 100g block but the location only supports stream(s) [1, 2, 3].
I have tried the example design, changing the device to the above board, but the build fails. Using Quartus 25.3.0
What is needed to move past these errors?
Thanks, Ed.
- EdCz
I have work-around the placement error, by the use of the "Tile Interface Planner" This has allowed Analysis & Elaboration to complete.
Synthesis however fails with the following errors:
Error(13076): The pin "ftile_eth|u0|eth_f_0|sip_inst|rd_ptr_sync|ml[0].lrm.CLK0[0]" has multiple drivers. Error(20073): "non-tri-state driver "f7aq1a_auto_tiles|z1577b_x3_y166_n0|x0_x0_u25_2_hdpldadapt_pld_pcs_tx_clk_out1_dcm"" is one of the multiple drivers. Error(20073): "non-tri-state driver "f7aq1a_auto_tiles|z1577b_x3_y166_n0|x0_x0_u25_2_hdpldadapt_pld_pma_internal_clk1_hioint"" is one of the multiple drivers.This appears to be a Quartus generation error or some IP configuration combination is not supported. What is the next step?
- RongY_altera
Contributor
The Quad location should be valid. Please make the clock only for ethernet (or temporary remove PCIe). In the qsf, not use "PRESERVE_UNUSED_XCVR_CHANNEL ON" and set all rx/tx_serial pins explicitly.
Rong
- EdCz
Rong,
Thank you for your suggestions!
I removed the F-Tile for the PCIe endpoint, and the PRESERVE_UNUSED_XCVR_CHANNEL settings. as suggested. The multiple-driver error remains. This error occurs within the <design>_auto_tiles hierarchy, so there is little I can do address this in my design.
Are there any other possilble work-arounds?
Many thanks,
Ed.- RongY_altera
Contributor
>>You need to check this clock. The report says it is driven by multiple sources.
>>You can also generate a 400G example design as a reference to confirm your clock connections.
Rong
- EdCz
The multiple clock error is deep inside of a hierarchy generated by Quartus. I have tried many configurations of the F-Tile and its clocking IP, but without success.
As for the 400G example design, while I can generate an example design, Quartus does not support the F-Series Development Kit 2xF-Tile DK-DEV-AGF023F. as a target device. Since I can successfully compile for other devices, I am assuming my configurations are correct.
This is blocking our use of the dual- F-Tile device for ethernet. Are you able to generate a 400G Ethernet for the 2xF-Tile dev kit?
Thanks, Ed.
- EdCz
Yes, The 400G uses the FGT Quad2 and Quad 3 (Bank 12C), with the ref clock #6 as REFCLK_FGTL12C_Q3_RX_CH6P. The schematic calls this out very nicely on page 20. I am able to verify these assignment with the Tile Interface Planner.
Ed.
- RongY_altera
Contributor
Using Q24.3.1 Pro to generate a FGT 400Gx8 example design and do migration to your target Dev Kit. The project can pass compilation.
I suggest you create the example design based on the current Quartus version you're using, rather than upgrading a project created by another version.
Rong
- RongY_altera
Contributor
Pasting full qsf will cause error. Here are the pins.
set_location_assignment PIN_CK18 -to i_reconfig_clk
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to i_reconfig_clk
set_instance_assignment -name INPUT_TERMINATION DIFFERENTIAL -to i_reconfig_clkset_location_assignment PIN_AD48 -to i_refclk2pll
set_instance_assignment -name IO_STANDARD "CURRENT MODE LOGIC (CML)" -to i_refclk2pll
set_location_assignment PIN_R49 -to o_tx_serial[0]
set_location_assignment PIN_V52 -to o_tx_serial[1]
set_location_assignment PIN_W49 -to o_tx_serial[2]
set_location_assignment PIN_AB52 -to o_tx_serial[3]
set_location_assignment PIN_AF52 -to o_tx_serial[4]
set_location_assignment PIN_AK52 -to o_tx_serial[5]
set_location_assignment PIN_AP52 -to o_tx_serial[6]
set_location_assignment PIN_AV52 -to o_tx_serial[7]
set_location_assignment PIN_K52 -to i_rx_serial[0]
set_location_assignment PIN_P52 -to i_rx_serial[1]
set_location_assignment PIN_R55 -to i_rx_serial[2]
set_location_assignment PIN_W55 -to i_rx_serial[3]
set_location_assignment PIN_AC55 -to i_rx_serial[4]
set_location_assignment PIN_AG55 -to i_rx_serial[5]
set_location_assignment PIN_AL55 -to i_rx_serial[6]
set_location_assignment PIN_AR55 -to i_rx_serial[7]
set_location_assignment PIN_T48 -to o_tx_serial_n[0]
set_location_assignment PIN_U51 -to o_tx_serial_n[1]
set_location_assignment PIN_Y48 -to o_tx_serial_n[2]
set_location_assignment PIN_AA51 -to o_tx_serial_n[3]
set_location_assignment PIN_AE51 -to o_tx_serial_n[4]
set_location_assignment PIN_AJ51 -to o_tx_serial_n[5]
set_location_assignment PIN_AN51 -to o_tx_serial_n[6]
set_location_assignment PIN_AU51 -to o_tx_serial_n[7]
set_location_assignment PIN_J51 -to i_rx_serial_n[0]
set_location_assignment PIN_N51 -to i_rx_serial_n[1]
set_location_assignment PIN_T54 -to i_rx_serial_n[2]
set_location_assignment PIN_Y54 -to i_rx_serial_n[3]
set_location_assignment PIN_AD54 -to i_rx_serial_n[4]
set_location_assignment PIN_AH54 -to i_rx_serial_n[5]
set_location_assignment PIN_AM54 -to i_rx_serial_n[6]
set_location_assignment PIN_AT54 -to i_rx_serial_n[7]set_global_assignment -name DEVICE AGFD023R24C2E1VC
#set_global_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON
