17 years agoErrors building Clocked Video Output
I added a Clocked Video output to a design and feed it with a scatter-gather DMA. There are two Avalon ST adapters in the path to make it work. I'm getting a bunch of errors like this: "...
13 years ago --- Quote Start --- You may also want to use a frame buffer before your clocked video output if for any reason the SGDMA block cannot output the data fast enough to keep the clocked video output's internal FIFOs from starving. --- Quote End --- Not only Clocked Video Output has FIFO. SGDMA also seems to have built-in FIFO. FPGA's internal memory also can be used as an additional FIFO to prevent Clocked Video Output's FIFO from underflowing. What really can happen in Windows environement when all these FIFOs could be not enough and only presence of a Framebuffer could prevent loss of videodata?
