17 years agoDSP Builder to ModelSim
Hi , im just perform RTL simulations with the ModelSim software. I add a TestBench block to my DSP builder model. Then I get the following error:
# ** Error: (vsim-3817) Formal port "clk" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "reset" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in1" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in2" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in3" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in4" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in5" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in6" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in7" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3817) Formal port "data_in8" declared in the entity is not in the component. # Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input3' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output4' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input7' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'aclr' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input8' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'clock' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input4' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output5' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output1' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output6' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input5' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'dpt2_subsystem_output8' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input2' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output2' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input6' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output7' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'input1' is not on the entity.) # Region: /tb_dpt2/dut # ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'. # (Port 'output3' is not on the entity.) # Region: /tb_dpt2/dut # ** Fatal: Bad library format, library not compiled with ALTERA compiler. # # Time: 0 ps Iteration: 0 Instance: /tb_dpt2/clock File: UNKNOWN Line: 293 # FATAL ERROR while loading design # Error loading design # Unrecognized dataset prefix: sim can someone help me with this? thanks !!!13 Replies
It might help if you gave a little more information. Does your design compile in Quartus? Does it simulate correctly in Simulink?
Perhaps post a screenshot of your design if not the design (cut down as much as possible to demonstrate the failure) itself. - Altera_Forum
--- Quote Start --- It might help if you gave a little more information. Does your design compile in Quartus? Does it simulate correctly in Simulink? Perhaps post a screenshot of your design if not the design (cut down as much as possible to demonstrate the failure) itself. --- Quote End --- thanks for the reply! yes it compiled smoothly in quartus and run perfectly in simulink. and all the port name mention in the error are from the attached vhdl file. - Altera_Forum
Is the name of your original VHDL file and the model the same?
It kind of looks like it's loading your top-level VHDL as the HDL Import or vice versa. If so try to make sure that the names do not clash. - Altera_Forum
--- Quote Start --- Is the name of your original VHDL file and the model the same? It kind of looks like it's loading your top-level VHDL as the HDL Import or vice versa. If so try to make sure that the names do not clash. --- Quote End --- hmmm..im pretty sure there is no clash between the name of the file and the model... - Altera_Forum
I should have clarified it's the name of the entity in the file not the file itself that will clash.
In your original log you have tb_dpt2, which seems to indicate your original model was called dpt2. It also references DSPBuilder_dpt2_import/dpt2.vho, which would indicate you imported a file called dpt2.vhd via HDL Import. Also you might have some stale files around. Try deleting the DSPBuilder_dpt2_import and tb_dpt2 directories and regenerate. - Altera_Forum
--- Quote Start --- I should have clarified it's the name of the entity in the file not the file itself that will clash. In your original log you have tb_dpt2, which seems to indicate your original model was called dpt2. It also references DSPBuilder_dpt2_import/dpt2.vho, which would indicate you imported a file called dpt2.vhd via HDL Import. Also you might have some stale files around. Try deleting the DSPBuilder_dpt2_import and tb_dpt2 directories and regenerate. --- Quote End --- thank you very much! i got this problem solved!! in the model, i set the inputs through the matlab function blockset with function defined as: double(rgb2gray(imread('pic.tif'))) but why cant this value been shown in the modelsim? - Altera_Forum
and i have the following error message when i Compare Simulink Result with Modelsim:
Error: Error opening HDL output file dpt2_Output.capture.msim :: Missing data type 'null' in file dpt2_Output.capture.msim Error: Mismatch between ModelSim and Simulink outputs. Please refer to the DSPBuilder trouble-shooting guide for more information. - Altera_Forum
Have you consulted the DSP Builder trouble-shooting guide?
--- Quote Start --- Have you consulted the DSP Builder trouble-shooting guide? --- Quote End --- yes, just checked and do some checking on google. havent found anything useful so far - Altera_Forum
I think the missing data type message about the capture.msim files is because modelsim failed halfway through. Are there perhaps more error messages further up?
