17 years agoDSP Builder to ModelSim
Hi , im just perform RTL simulations with the ModelSim software. I add a TestBench block to my DSP builder model. Then I get the following error: # ** Error: (vsim-3817) Formal port "clk" decl...
17 years ago --- Quote Start --- It might help if you gave a little more information. Does your design compile in Quartus? Does it simulate correctly in Simulink? Perhaps post a screenshot of your design if not the design (cut down as much as possible to demonstrate the failure) itself. --- Quote End --- thanks for the reply! yes it compiled smoothly in quartus and run perfectly in simulink. and all the port name mention in the error are from the attached vhdl file.
