17 years agoDSP Builder to ModelSim
Hi , im just perform RTL simulations with the ModelSim software. I add a TestBench block to my DSP builder model. Then I get the following error: # ** Error: (vsim-3817) Formal port "clk" decl...
17 years agoI should have clarified it's the name of the entity in the file not the file itself that will clash.
In your original log you have tb_dpt2, which seems to indicate your original model was called dpt2. It also references DSPBuilder_dpt2_import/dpt2.vho, which would indicate you imported a file called dpt2.vhd via HDL Import. Also you might have some stale files around. Try deleting the DSPBuilder_dpt2_import and tb_dpt2 directories and regenerate.
