CXL type 3 example design increase to 128GB per channel?
What needs to change in the CXL type 3 example design to increase the Memory to 128GB per channel?
I tried changing the emif IP to a DIMM, and updated the scripts to not define ENABLE_DDR_DBI_PINS. I updated the pinouts. But I get:
Error(129015): Output port DATA_OUT on atom "ed_top_wrapper_typ3_inst|MC_CHANNEL_INST[0].mc_top|GEN_CHAN_COUNT_EMIF[0].emif_inst|emif|arch|arch_inst|io_tiles_wrap_inst|io_tiles_inst|tile_gen[1].lane_gen[2].lane_inst|lane_inst", which is a tennm_io_12_lane primitive, is not legally connected and/or configured
Info(129016): Output port DATA_OUT[8] is disconnected, but the Compiler expects this output port to be connected
Any idea what I am missing?
- brian1211
@crclayton I think this error was actually simply a duplicate pin declaration, so same IP IO pin had 2 set_location_assignments to 2 different package pins. Hope that helps.
- crclayton
Thank you!
- nelky
Hi brian1211,
What is the solution?
I got the similar error,
Error(129015): Output port DATA_OUT on atom "soc_inst|emif_hps|emif_hps|arch|arch_inst|io_tiles_wrap_inst|io_tiles_inst|tile_gen[1].lane_gen[0].lane_inst|lane_inst", which is a tennm_io_12_lane primitive, is not legally connected and/or configured
Hope to hear from you soon.
- brian1211
Tried to attach a *.qar but it's too big.
- JonWay_altera
Hi @brian1211 i have sent you an personal message.
- crclayton
What was the solution here? I am also seeing reports of this error.
