CVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach this frequency as far as running the chain of IP but when I clock the video out of the CVO Time Quest is telling me a maximum frequency of around 170 - 180MHz. Does anyone have any thoughts on this? I need to run my output clock around 260MHz which I thought I could hit per the User Guide but the tools are telling me differently. Thanks.
--- Quote Start --- there doesn't seem to be a rule on when you need .sdc files. some get generated in the project directory, some are in the IP install directory, and some are embedded in the core --- Quote End --- I didn't know there were SDC files to add for the CVI and CVO. I have never had timing problems with them, but I suppose I should be using the SDC files just to be sure. I find it really annoying that the SDC files for generated IP do not automatically get included in all cases. Just yesterday I wasted several hours trying to get a DDR SDRAM controller working until I realized I forgot to include the SDC file. Of course, the solder ball between two of the data pins didn't help either... - Altera_Forum
Kind of like rock-paper-scissors except solder balls always win.
Today I switched over to using the 10.0 tools on another PC. I noticed that the CVO and CVI .sdc files were automatically added to the project - whereas they weren't in 9.0. Another note. I was using the Timing Advisor to increase my FMax. As I added in the recommended options my FMax dropped. I'm sure it all depends on the design but something to keep in mind and not just blindly go with their recommendations. - Altera_Forum
I also noticed today that the .sdc file for the CVI is added automatically in Quartus II 10.0. I also checked the VIP user guide, and it still indicates you need to add them manually. It only mentions adding SDC files for CVI and CVO, however I searched my install folder and found all of the following:
C:\altera\10.0\ip\altera\clocked_video_input\alt_vipcti100_cvi.sdc C:\altera\10.0\ip\altera\clocked_video_output\alt_vipitc100_cvo.sdc C:\altera\10.0\ip\altera\deinterlacer\alt_vip_dil.sdc C:\altera\10.0\ip\altera\frame_buffer\alt_vip_vfb.sdc C:\altera\10.0\ip\altera\frame_reader\alt_vipvfr100_vfr.sdc I didn't try all of the cases, but at least for the frame buffer (VFB), the sdc file is not added automatically. - Altera_Forum
interesting, so just take the time to check the cores that interface to the outside world
rogerleo: the method used in larger than 1080p video streams was actually multiple 1080p streams stitched together. either way looks like you'll have to write some logic
