16 years agoCVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach t...
16 years agoKind of like rock-paper-scissors except solder balls always win.
Today I switched over to using the 10.0 tools on another PC. I noticed that the CVO and CVI .sdc files were automatically added to the project - whereas they weren't in 9.0. Another note. I was using the Timing Advisor to increase my FMax. As I added in the recommended options my FMax dropped. I'm sure it all depends on the design but something to keep in mind and not just blindly go with their recommendations.
