16 years agoCVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach t...
16 years agointeresting, so just take the time to check the cores that interface to the outside world
rogerleo: the method used in larger than 1080p video streams was actually multiple 1080p streams stitched together. either way looks like you'll have to write some logic
