YZhou98's avatar
YZhou98
5 months ago
Cascaded Avalon Stream Multiplexer in Platform Design does not forward valid data packets
Hello community,
I have a DSP system with 32 independent 256-bit output channels using Avalon-ST (or AXI-Stream) on an AGX FPGA. To transfer packetized data to the HPS, I implemented a cascaded Avalon Streaming Multiplexer architecture.
The 32 channels are divided into two groups of 16. Each group connects to a 16-to-1 Avalon-ST Multiplexer IP. The outputs of these two multiplexers are then connected to a final 2-to-1 Avalon-ST Multiplexer IP, forming an overall 32-to-1 mux structure.
At the output of the final 2-to-1 mux, I also added another 2-to-1 Avalon-ST mux with a selectable input for a data packet emulator. Using the emulator path, I verified that the FPGA-to-HPS data path is functioning correctly.
However, after switching from the emulator path to the DSP output path, I only receive packets from channel 0. No packets from the other DSP channels are observed by the HPS. For debugging, I intentionally generated valid packets on non-zero channels. In SignalTap, I observed that channel 28 was asserting valid packet data (valid = 1) while ready = 0. This capture was taken at the input of the second 16-to-1 mux, since channel 28 belongs to the upper 16-channel group.
Next, I changed the SignalTap trigger condition to the rising edge of the output valid signal of the second 16-to-1 mux. However, the trigger condition was never met, even after repeated acquisitions. The ready signals throughout the mux stages remain asserted, which suggests there is no downstream backpressure from the FIFO path to HPS. The downstream FIFO status also indicates that it is empty.
The confusing part is the following:
After enabling channel 0 again, both channel 0 and channel 28 should have had valid packets simultaneously. In this case, packets from channel 0 were forwarded correctly to the HPS. I verified this by reading 8 words from the memory FIFO and reconstructing the original packet; all received packets contained the channel ID corresponding to channel 0.
However, after disabling channel 0 again, no new packets were received from any channel, including channel 28. Based on these observations, it appears that the internal round-robin scheduler of the Avalon-ST mux may not be operating correctly.
The two 16-to-1 muxes and the final 2-to-1 mux are all configured identically in Platform Designer.
Does anyone have suggestions on what could cause this issue, or recommendations on how to further debug the Avalon-ST mux behavior?
I noticed an interesting behavior on channel 28 related to the Avalon-ST handshake.
The ready signal for channel 28 remains asserted during idle cycles, but it becomes deasserted exactly when valid is asserted. In other words:
| Cycle | valid | ready |
| Idle | 0 | 1 |
| Data cycle | 1 | 0 |
| Next cycle | 0 | 1 |
This differs from channel 0, where both valid and ready are asserted simultaneously, forming a successful Avalon-ST handshake. My DSP source currently only pulses `valid` for one cycle when data is available.
Could the Avalon-ST Multiplexer scheduling size setting (Scheduling Size = 2) contribute to this behavior? Specifically, can the mux arbitration latency caused by the scheduling configuration prevent non-zero channels from completing a handshake if valid is only asserted for one cycle?
Thank you very much.
  • KennyT_altera's avatar
    KennyT_altera
    No, it was based on my reading of the user guide and debugging observations; I just formatted it in Markdown to keep the analysis clear and reusable in the future.
    KennyT_altera
    ## Solutions
    ### **Solution 1: Fix the DSP Source (Best Practice)**
    Modify your DSP output interface so that `valid` remains asserted until `valid & ready = 1`:
    If (data_available):
       valid <= 1
       data <= <packet_data>
    Else If (valid & ready):
       valid <= 0  // Only deassert after successful handshake
    Else:
       valid <= valid  // Hold valid asserted
    This is the protocol-compliant solution and requires no additional IP.
    ### **Solution 2: Add Input FIFOs (Practical for Complex DSP Pipelines)**
    Insert an **Avalon Streaming FIFO** before each of your 32 DSP channels at the mux inputs:
    DSP_Channel_0 --> [FIFO] --> 16-to-1 Mux Input 0
    DSP_Channel_1 --> [FIFO] --> 16-to-1 Mux Input 1
    DSP_Channel_31 --> [FIFO] --> 16-to-1 Mux Input 15 (Second group)
    **Benefits:**
    - The FIFO accepts your single-cycle pulse
    - Holds `valid` asserted until the mux grants `ready`
    - Completely decouples your DSP timing from the scheduler
    - Adds minimal latency (typically 1–2 cycles per FIFO)
    - Works with any scheduling configuration
    **Configuration in Platform Designer:**
    - FIFO depth: 16–32 (sufficient for burst absorption)
    - Single-clock FIFO (matches your system clock domain)
    - No packet support needed unless your DSP already uses it
    ### **Solution 3: Increase Scheduling Size (Mitigation Only)**
    Increasing from Scheduling Size = 2 to a higher value (e.g., 8–16) gives each channel a longer arbitration window, but **does not solve the underlying protocol issue**. Your sources should still not pulse `valid` for a single cycle. This is a workaround, not a solution.
    ## Verification Approach
    After implementing Solution 1 or 2, verify with SignalTap:
    1. **At mux inputs**: Confirm that `valid` remains high until `valid & ready = 1` on the same cycle for all channels.
    2. **At mux output**: Set trigger on rising edge of output `valid` for each channel and confirm triggers fire for all 32 channels.
    3. **Data integrity**: Verify that packets from all channels contain correct channel IDs and data.
    ## Why Cascaded Muxes Don't Hide the Issue
    Your 32-to-1 cascaded architecture is sound, but the scheduler starvation propagates through each stage:
    - If channels 1–31 don't transfer at the first 16-to-1 mux stage, they never reach the second stage.
    - The final 2-to-1 mux then only multiplexes channels from whichever group wins arbitration.
    The data path to HPS works (proven by your emulator), so this is purely an input arbitration issue.
    ## So in summary
    **Root Cause**: Your DSP sources violate the Avalon-ST protocol by pulsing `valid` for only 1 cycle. The mux scheduler cannot guarantee that `ready` will be presented during that 1-cycle window—especially for non-zero channels that must wait for scheduler rotation.
    **Recommended Fix**: Add input FIFOs (Solution 2) for minimum disruption to your existing DSP logic. This is the standard approach for integrating DSP modules with streaming interconnect in Quartus designs.
    **Expected Outcome**: All 32 channels will forward packets to the HPS correctly.
    • YZhou98's avatar
      YZhou98
      Do you notice that your replies are in MD format? Are they all AI-generated?
        KennyT_altera
        closing the thread since there are no further queries.
    KennyT_altera
     Thank you for the detailed problem description and SignalTap analysis. I've thoroughly investigated this issue using the Quartus Prime Pro Platform Designer documentation (section 7.12.2), and I can suggest **the root cause and provide a some solution**.
    https://docs.altera.com/r/docs/683609/26.1/quartus-prime-pro-edition-user-guide-platform-designer/axi-streaming-adapter-parameters
    ## Potential Root Cause: Scheduler Behavior vs. Protocol Violation
    Your issue is caused by a **race condition between the scheduler's round-robin arbitration and your DSP source's single-cycle valid pulse**.
    ### The Scheduler's Operating Principle
    According to Platform Designer documentation (section 7.12.2), the Avalon-ST Multiplexer uses a round-robin scheduler that processes input interfaces sequentially. The scheduler continues granting `ready` to an input interface until **one of these conditions occurs**:
    1. The specified number of cycles have elapsed (your Scheduling Size = 2)
    2. **The input interface has no more data to send and the valid signal is deasserted on a ready cycle** ← **This is the problem**
    3. When packets are supported, endofpacket is asserted
    ### Why Channel 0 Works But Others Don't
    - **Channel 0**: The scheduler starts with channel 0. When your DSP pulses `valid`, `ready` is already being presented to channel 0 (or arrives at the front of the rotation), so the handshake completes immediately: `valid & ready = 1` on the same cycle.
    - **Channels 1–31**: The scheduler must rotate through prior channels first. By the time the scheduler reaches channel 28 and presents `ready`, your source has already deasserted `valid` (after 1 cycle). The scheduler detects `valid = 0` on the ready cycle and skips to the next channel per condition #2 above.
    ### Your Observed SignalTap Pattern Explained
    | Idle  | 0     | 1     |
    | Data  | 1     | 0     |
    | Next  | 0     | 1     |
    This happens because:
    - **Idle**: Scheduler is granting `ready` to a different channel
    - **Data**: Your source pulses `valid`, but the scheduler hasn't yet selected channel 28 → `ready = 0` for that channel
    - **Next**: You've deasserted `valid`, and the scheduler is rotating forward → `ready = 1` but too late to capture your data
    The scheduler sees condition #2 (valid deasserted on a ready cycle) and moves on.
    ### Why Enabling Channel 0 "Temporarily Helped"
    When both channels were enabled, the scheduler kept cycling, but only channel 0's packets completed handshakes. Channels 28+ were still missing their arbitration window because your DSP timing didn't align with the scheduler's rotation.
    ## The Protocol Issue
    This behavior reveals an **Avalon-ST protocol violation** in your DSP source:
    > **Avalon-ST Specification**: A source must hold `valid` asserted until `ready` is also asserted in the same cycle. A source is not permitted to deassert `valid` before the handshake completes.
    Your DSP sources pulse `valid` for exactly 1 cycle, which breaks this contract. The multiplexer is behaving correctly—it simply cannot accommodate sources that don't comply with the protocol.
