13 years agoCan Avalon-ST Dual Clock FIFO's fifo depth exceed 32?
accroding to the spec <ug_embedded_ip>P15-4,the descriptions for parameter 'FIFO depth',legal value is ONLY 1~32.
But when I use Qsys ver 12.0 to add the DC_FIFO component,I can type in '1024' to the parameter 'FIFO depth' of DC_FIFO,without error reminding. What is it?Can FIFO depth of DC_FIFO exceed 32? Thanks for any reply. Regards!4 Replies
That's a documentation error. I don't know what the maximum is but I know it is much larger than 32. I've used 1k before so you should be fine with that setting.
Thank you very much!
And yesterday when I use Qsys,type in '2000'to FIFO depth,it reminds me that "the FIFO depth has to be a power of 2."I think it may be a error in the doc or I confused it. - Altera_Forum
You are better off rounding that up to 2048. The memory blocks in the FPGA which make up the storage element of the FIFO have densities that are a power of two. I have flagged these documentation errors so they should be corrected the next time the document is updated.
Thank you again~
