13 years agoCan Avalon-ST Dual Clock FIFO's fifo depth exceed 32?
accroding to the spec <ug_embedded_ip>P15-4,the descriptions for parameter 'FIFO depth',legal value is ONLY 1~32. But when I use Qsys ver 12.0 to add the DC_FIFO component,I can type in '1024' to ...
13 years agoYou are better off rounding that up to 2048. The memory blocks in the FPGA which make up the storage element of the FIFO have densities that are a power of two. I have flagged these documentation errors so they should be corrected the next time the document is updated.
