Associate an individual mif file to each RAM memory instantiated by a "generate"
I instantiate RAM memories with the following VHDL code :
gen_inst_ram_0to7 :
for i in 0 to 7 generate
inst_ram : ram
port map(
address_a => w_address_a(i),
address_b => w_address_b(i),
clock => clk,
data_a => w_data_a(i),
data_b => w_data_b(i),
wren_a => w_wren_a(i),
wren_b => w_wren_b,
q_a => w_data_out_a(i),
q_b => w_data_out_b(i)
end generate gen_inst_ram_0to7;
I would like to use memory initialization files (*.mif) but don't know how to link the 8 files to the 8 instanciations.
Could you give me a hint to do such thing ?
Thank you.
- RichardT_altera
You can try to study the RAM VHDL design code in Quartus. In the new VHDL file, right-click and "insert template". Find VHDL > Full Designs > RAMs and ROMs > Single-Port RAM with Initial Contents.
There is a part of the design code on how to use .mif file. Or you can instantiate it using the Quartus IP Catalog. Hope it helps.
- ADufl
Thank you for your answer but this template covers the case of using a *.mif file to set the initial state of an explicitly instantiated RAM block. My issue is about doing so when the RAM blocks have been instantiated using a "generate" statement.
Thank you for your support.
- RichardT_altera
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
- ADufl
As requested, I replied to your answer, stating that it what well suited for my case but you didn't pursue. I was less available those last 16 month but we can now resume support.
My issue is about using *.mif files when the RAM blocks have been instantiated using a "generate" statement.
- ADufl
My issue is still active, is there a way to link *.mif initalization files when the RAM blocks have been instantiated using a "generate" statement ?
