ADufl
5 years agoAssociate an individual mif file to each RAM memory instantiated by a "generate"
I instantiate RAM memories with the following VHDL code :
gen_inst_ram_0to7 : for i in 0 to 7 generate inst_ram : ram port map( address_a => w_address_a(i), address_b => w_address_b...
RichardT_altera
5 years agoYou can try to study the RAM VHDL design code in Quartus. In the new VHDL file, right-click and "insert template". Find VHDL > Full Designs > RAMs and ROMs > Single-Port RAM with Initial Contents.
There is a part of the design code on how to use .mif file. Or you can instantiate it using the Quartus IP Catalog. Hope it helps.
ADufl
5 years agoThank you for your answer but this template covers the case of using a *.mif file to set the initial state of an explicitly instantiated RAM block. My issue is about doing so when the RAM blocks have been instantiated using a "generate" statement.
Thank you for your support.
