11 years agoaltera_onchip_flash
The submodule "altera_onchip_flash_avmm_data_controller" in this IP has some problem.
WRITE_STATE, this FSM will unexpectedly been hold when I continues write data to flash. It will cause status stock in write busy. csr_readdata[1:0] will equal to 2'b10 which means BUSY_WRITE for a long time. It might be something wrong with its' state machine. I guess the register "write_count " is overflow, so I replace "write_count != 0" to "write_count > 0" . Finally, it work out. // ------------------------------------------------------------------- // Avalon_MM data interface fsm - communicate between Avalon_MM and Flash IP (Write Operation) // -------------------------------------------------------------------4 Replies
// Avalon_MM data interface fsm - communicate between Avalon_MM and Flash IP (Write Operation) // ------------------------------------------------------------------- always @ (posedge clock) begin if (~reset_n_w) begin write_state <= WRITE_STATE_IDLE; write_wait <= 0; end else begin case (write_state) WRITE_STATE_IDLE: begin // reset all register write_count <= 0; write_timeout <= 1'b0; enable_drclk_neg_pos_write_reg <= 0; // check command if (avmm_write) begin if (~valid_csr_erase && ~is_erase_busy && ~is_read_busy) begin write_wait <= 1; // address legality check if (is_addr_writable && is_valid_write_burst_count) begin write_state <= WRITE_STATE_WRITE; write_count <= DATA_WIDTH[5:0]; end else begin write_state <= WRITE_STATE_ERROR; write_wait <= 0; write_count <= 2; end end end end WRITE_STATE_WRITE: begin if (write_count > 0) begin//(write_count != 0) begin write_drclk_en <= 1; write_count <= write_count - 16'd1; end else begin enable_drclk_neg_pos_write_reg <= 1; write_drclk_en <= 0; write_count <= FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_WAIT_BUSY; end end WRITE_STATE_WAIT_BUSY: begin if (flash_busy_reg) begin write_count <= FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_WAIT_DONE; end else begin if (write_count > 0) //(write_count != 0) write_count <= write_count - 16'd1; else begin write_timeout <= 1'b1; write_count <= FLASH_RESET_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_RESET; end end end WRITE_STATE_WAIT_DONE: begin if (~flash_busy) begin write_count <= FLASH_RESET_CYCLE_MAX_INDEX[5:0]; write_state <= WRITE_STATE_RESET; end else begin if (write_count > 0) begin//(write_count != 0) begin write_count <= write_count - 16'd1; end else begin write_timeout <= 1'b1; write_count <= FLASH_RESET_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_RESET; end end end WRITE_STATE_RESET: begin if (write_timeout) begin csr_status_w_pass <= 1'b0; end else begin csr_status_w_pass <= flash_sp_pass_reg; end if (write_count == 1) begin write_wait <= 0; end if (write_count > 0) begin//(write_count != 0) begin write_count <= write_count - 16'd1; end else begin write_state <= WRITE_STATE_IDLE; end end WRITE_STATE_ERROR: begin csr_status_w_pass <= 0; if (write_count == 1) begin write_wait <= 0; end if (write_count > 0) begin//(write_count != 0) begin write_count <= write_count - 16'd1; end else begin write_state <= WRITE_STATE_IDLE; end end default: begin write_state <= WRITE_STATE_IDLE; end endcase end end - Altera_Forum
i replace all (write_count != 0) to (write_count > 0) in the WRITE_STATE FSM
WRITE_STATE_WRITE: begin if (write_count > 0) begin//(write_count != 0) begin write_drclk_en <= 1; write_count <= write_count - 16'd1; end else begin enable_drclk_neg_pos_write_reg <= 1; write_drclk_en <= 0; write_count <= FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_WAIT_BUSY; end end - Altera_Forum
I do some simulation. Two type coding looks totally different on technology map.
A type coding : "write_count != 0" The FSM will fail if there is a glitch on clock. B type coding : "write_count > 0" The FSM will be fine if there is a glitch on clock. By the way, my device is MAX10. I think MAX10's clock may have some problem. Where can i share these simulation file? Can anyone teach me why these two type coding make so much different on the end? Thanks a lot. - Altera_Forum
I think you saw success with the modification you made because the actual problem is a timing error. You must have gotten lucky on the new compile to have it not lock up the internal logic. The real issue is a timing bug with the busy signal. The fix I put in place for the 14.1 standard release code was to change line 446 from:
always @ (negedge reset_n or negedge is_busy or posedge flash_osc) begin to always @ (negedge reset_n or negedge is_busy or posedge clock) begin The problem was that the flash_busy_reg signal needed to get latched in the clock domain, not the flash_osc domain. When I made this change it resolved all the timing errors and also worked flawlessly. After I reported this to Altera they informed me that there is a patch to install on 14.1 that also fixes this.
