11 years agoaltera_onchip_flash
The submodule "altera_onchip_flash_avmm_data_controller" in this IP has some problem. WRITE_STATE, this FSM will unexpectedly been hold when I continues write data to flash. It will cause status...
11 years agoI do some simulation. Two type coding looks totally different on technology map.
A type coding : "write_count != 0" The FSM will fail if there is a glitch on clock. B type coding : "write_count > 0" The FSM will be fine if there is a glitch on clock. By the way, my device is MAX10. I think MAX10's clock may have some problem. Where can i share these simulation file? Can anyone teach me why these two type coding make so much different on the end? Thanks a lot.
