11 years agoaltera_onchip_flash
The submodule "altera_onchip_flash_avmm_data_controller" in this IP has some problem. WRITE_STATE, this FSM will unexpectedly been hold when I continues write data to flash. It will cause status...
11 years ago// -------------------------------------------------------------------
// Avalon_MM data interface fsm - communicate between Avalon_MM and Flash IP (Write Operation) // ------------------------------------------------------------------- always @ (posedge clock) begin if (~reset_n_w) begin write_state <= WRITE_STATE_IDLE; write_wait <= 0; end else begin case (write_state) WRITE_STATE_IDLE: begin // reset all register write_count <= 0; write_timeout <= 1'b0; enable_drclk_neg_pos_write_reg <= 0; // check command if (avmm_write) begin if (~valid_csr_erase && ~is_erase_busy && ~is_read_busy) begin write_wait <= 1; // address legality check if (is_addr_writable && is_valid_write_burst_count) begin write_state <= WRITE_STATE_WRITE; write_count <= DATA_WIDTH[5:0]; end else begin write_state <= WRITE_STATE_ERROR; write_wait <= 0; write_count <= 2; end end end end WRITE_STATE_WRITE: begin if (write_count > 0) begin//(write_count != 0) begin write_drclk_en <= 1; write_count <= write_count - 16'd1; end else begin enable_drclk_neg_pos_write_reg <= 1; write_drclk_en <= 0; write_count <= FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_WAIT_BUSY; end end WRITE_STATE_WAIT_BUSY: begin if (flash_busy_reg) begin write_count <= FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_WAIT_DONE; end else begin if (write_count > 0) //(write_count != 0) write_count <= write_count - 16'd1; else begin write_timeout <= 1'b1; write_count <= FLASH_RESET_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_RESET; end end end WRITE_STATE_WAIT_DONE: begin if (~flash_busy) begin write_count <= FLASH_RESET_CYCLE_MAX_INDEX[5:0]; write_state <= WRITE_STATE_RESET; end else begin if (write_count > 0) begin//(write_count != 0) begin write_count <= write_count - 16'd1; end else begin write_timeout <= 1'b1; write_count <= FLASH_RESET_CYCLE_MAX_INDEX[15:0]; write_state <= WRITE_STATE_RESET; end end end WRITE_STATE_RESET: begin if (write_timeout) begin csr_status_w_pass <= 1'b0; end else begin csr_status_w_pass <= flash_sp_pass_reg; end if (write_count == 1) begin write_wait <= 0; end if (write_count > 0) begin//(write_count != 0) begin write_count <= write_count - 16'd1; end else begin write_state <= WRITE_STATE_IDLE; end end WRITE_STATE_ERROR: begin csr_status_w_pass <= 0; if (write_count == 1) begin write_wait <= 0; end if (write_count > 0) begin//(write_count != 0) begin write_count <= write_count - 16'd1; end else begin write_state <= WRITE_STATE_IDLE; end end default: begin write_state <= WRITE_STATE_IDLE; end endcase end end
