17 years agoALT2GXB loopback problem
I'm using an Arria EP1AGX60CF484C6 with an ALT2GXB core configured in XAUI mode (4 lanes). I'm trying to do a loopback to test it out. The loopback is in the core, so what I've done is connect the rx_dataout (64-bit) to the tx_datain (64-bit) and connect the rx_ctrldetect (8 bits) to the tx_ctrlenable(8 bits). The gxb_powerdown is permantely tied to a logic 0. The resets have been staggered so that the rx_analog is released first followed by the rx_digital followed by the tx_digital sections. The input clock is 156.25MHz. I'm using a HP Pro Curve Switch 6400cl to try to ger a link between the FPGA and the switch. I know that the Tx PLL is locking as this goes to an LED. I know that the Rx PLL is locking and it's switching over to lock on to the incoming data (rx_freqlocked is also output to an LED). I'm also watching the debug_rx_phase_comp_fifo_error[3:0] and debug_tx_phase_comp_fifo_error[3:0] - only bit 0 of each (they also go to LED's). I find that the debug_tx_phase_comp_fifo_error[0] seems to go high which suggests the tx FIFO has an overrun/underrun problem. Both the Tx and Rx FIFO's are being clocked by coreclockout which is generated by the GXB. I'm not sure why there is an error as the timing report seems to state there is no issue with timing. I've never used a GXB block before and I've been working my way through it trying various things to see if I can get it to work. I don't know if putting it in loopback is as simple as I've described or if there's a sequence that I need to follow. And I don't understand the fifo error flag either as timing seems to be ok. Thanks MT
