17 years agoALT2GXB loopback problem
Hi, I'm using an Arria EP1AGX60CF484C6 with an ALT2GXB core configured in XAUI mode (4 lanes). I'm trying to do a loopback to test it out. The loopback is in the core, so what I've done is con...
14 years agoHi,
you have to include control and status ports for the XAUI - Megafunction in the Wizard. (Advanced Options if you are using XAUI Phy Megafunction). Then you can use SignalTap to check the rx_errdetect signal. SignalTap is an Onchip Logic Analyzer which is accessible from Quartus Tools Menu. Jens
