Serge93's avatar
Serge93
11 months ago
AGILEX 5E : GTS AXI IP PCI Express : What is the mapping of the PCIe Header on _tuser_hdr[255:0]
In AGILEX 5E : GTS AXI Streaming IP for PCI Express user guide : ug-813754-855610.pdf
What is the mapping of the PCIe Header on "_tuser_hdr[255:0]" signal when the PCIe0/1 AXI-ST Sideband Header parameter is enabled.
We have the mapping for the Tdata signal but not for the _tuser_hdr[255:0] signal.
Is it the same mapping ?
Thank you.
Serge
  • Hi @Serge93 ,
    The header format for inband and sideband is the same, thus we do not have a separate set of definition for sideband header.
    We will include this information more explicit in our next IP UG version.
    Wincent_Altera
  • Wincent_Altera's avatar
    Wincent_Altera
    Hi Serge,
    Based on my understanding, The mapping of the fields in _tuser_hdr is NOT the same as the mapping in tdata. tdata contains the actual TLP data (including header and payload),
    the _tuser_hdr contains just the header and sideband fields (if I not mistaked), in a format defined by Altera for easier access to header information.
    • The mapping of _tuser_hdr[255:0] is usually (For real cases, I suggest check the example design or simulation)
      [127:0] = PCIe TLP Header (DW0-DW3, 32 bits each)
      [255:128] = Sideband signals or reserved
    Wincent
    • Serge93's avatar
      Serge93
      Hello Wincent,
      Thank you for your answer but I meant the detail mapping as the following picture for Tdata :
      Do you have the same for the _tuser_hdr[255:0] signals ?
      Thank you.
      Serge
        Wincent_Altera
        Hi ,
        Thanks for your clarification, let me have sometime to check it.
        Get back to you later.
        Wincent_Altera
