AGILEX 5E : GTS AXI IP PCI Express : What is the mapping of the PCIe Header on _tuser_hdr[255:0]
- 11 months ago
Hi @Serge93 ,
The header format for inband and sideband is the same, thus we do not have a separate set of definition for sideband header.
We will include this information more explicit in our next IP UG version.
Wincent_Altera
Hi Serge,
Based on my understanding, The mapping of the fields in _tuser_hdr is NOT the same as the mapping in tdata. tdata contains the actual TLP data (including header and payload),
the _tuser_hdr contains just the header and sideband fields (if I not mistaked), in a format defined by Altera for easier access to header information.
- The mapping of _tuser_hdr[255:0] is usually (For real cases, I suggest check the example design or simulation)
[127:0] = PCIe TLP Header (DW0-DW3, 32 bits each)
[255:128] = Sideband signals or reserved
Wincent
Hello Wincent,
Thank you for your answer but I meant the detail mapping as the following picture for Tdata :
Do you have the same for the _tuser_hdr[255:0] signals ?
Thank you.
Serge
- Wincent_Altera11 months ago
Hi ,
Thanks for your clarification, let me have sometime to check it.
Get back to you later.
Wincent_Altera - Wincent_Altera11 months ago
Hi @Serge93 ,
Wincent_Altera- Serge9311 months ago
Thank you Wincent.
Serge
Hi Serge,
You are most welcome, if you have any question please do file a new forum thread.
We will be there to ensure your success.
Regards,Wincent_Altera
