JoshuaWillson's avatar
JoshuaWillson
11 months ago
Agilex 5 GTS Supported Protocols
Hi Altera/Community,
I’m trying to better understand the protocols supported by the Agilex 5 GTS transceivers. In the user guide, it mentions that the supported protocol is 10GBase-LR.
I wanted to confirm: is 10GBase-R the underlying protocol used before the optical module?
Also, does this mean that other optical modules, such as 10GBase-SR, are supported as well?
Any clarification on how the transceivers interact with different optical modules would be greatly appreciated.
Thanks in advance!
  • FvM's avatar
    FvM
    looking at IEEE Std 802.3-2015 Section 4, the only difference between 10GBASE-SR and 10GBASE-LR is different PHY wavelength and respective capability signaling at management layer. Thus missing -SR capability can be most likely fixed in IP code.
    Regards Frank
  • Hello Joshua,
    Is 10GBase-R the underlying protocol used before the optical module?
    • Yes, 10GBase-R is the base physical layer that the transceiver implements electrically.
    • Generally, yes. The transceiver can work with other 10G optical modules such as 10GBase-SR, as long as they use the same line rate and comply with the electrical interface spec.
    Pavee
    • shashwatss's avatar
      shashwatss
      Is there a list of qualified Transceivers available? If not, the above info is currently incomplete, as SFP+ and QSFP+ Transceivers are often vendor-locked. The Intel E10GSFPSR did not work in my case. Which transceivers are used by Intel(Altera) for qualifiying/testing the development board DK-A5E065AB32AEA ?
    • paveetirrasrie_Altera's avatar
      Hello Joshua,
      I've rechecked with internal team here. And yes you're right. Based on UG, it supports based on what mentioned in User Guide.
      I had misconception that if it comply with electrical spec and line rate, it should work regardless. My theory was not right, silly me.
      Apologies for the confusion and I hope you've gotten your answer.
      Pavee
    • JoshuaWillson's avatar
      JoshuaWillson
      HI paveetirrasrie_Altera​
      I have the Agilex 5E Premium Devkit.
      When I use a 10GBase-SR SFP+ module, it does not work. When I use a 10GBase-LR SFP+ module it starts to work.
      I think based off the GTS User Guide, Only 10Gbase-LR is currently supported!
        Hello Joshua,
        I hope you've got your answer. Hence, I'll close the thread for now.
        If you have a new question, feel free to open a new thread to get the support from Altera experts.
        Thanks, Frank for the additional information!!
        Pavee
