JoshuaWillson
11 months agoAgilex 5 GTS Supported Protocols
Hi Altera/Community, I’m trying to better understand the protocols supported by the Agilex 5 GTS transceivers. In the user guide, it mentions that the supported protocol is 10GBase-LR. I wante...
paveetirrasrie_Altera
10 months agoHello Joshua,
Is 10GBase-R the underlying protocol used before the optical module?
- Yes, 10GBase-R is the base physical layer that the transceiver implements electrically.
Also, does this mean that other optical modules, such as 10GBase-SR, are supported as well?
- Generally, yes. The transceiver can work with other 10G optical modules such as 10GBase-SR, as long as they use the same line rate and comply with the electrical interface spec.
Pavee
I've rechecked with internal team here. And yes you're right. Based on UG, it supports based on what mentioned in User Guide.
I had misconception that if it comply with electrical spec and line rate, it should work regardless. My theory was not right, silly me.
Apologies for the confusion and I hope you've gotten your answer.
Pavee
