Agilex 5 GTS Supported Protocols
Hello Joshua,
Is 10GBase-R the underlying protocol used before the optical module?
- Yes, 10GBase-R is the base physical layer that the transceiver implements electrically.
Also, does this mean that other optical modules, such as 10GBase-SR, are supported as well?
- Generally, yes. The transceiver can work with other 10G optical modules such as 10GBase-SR, as long as they use the same line rate and comply with the electrical interface spec.
Pavee
HI paveetirrasrie_Altera
I have the Agilex 5E Premium Devkit.
When I use a 10GBase-SR SFP+ module, it does not work. When I use a 10GBase-LR SFP+ module it starts to work.
I think based off the GTS User Guide, Only 10Gbase-LR is currently supported!
- paveetirrasrie_Altera10 months ago
Hello Joshua,
I hope you've got your answer. Hence, I'll close the thread for now.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Otherwise, the community users will continue to help you on this thread.Thanks, Frank for the additional information!!
Pavee
