15 years ago
XAUI Phy in Stratix IV GX
actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started with the ALTGX and ALTGX_RECONFIG Megafunctions and a pattern generator in conjunction with a pattern checker. This little testdesign works fine in some cases. Mostly the lanes on the receiver are mixed up compared to the transmitter even though the rx_channelaligned signal is set to '1' from the ALTGX function.
There is an example desing on Alterawiki (http://www.alterawiki.com/wiki/xaui_design_example_1 (http://www.alterawiki.com/wiki/xaui_design_example_1) for Stratix V. This example use the XAUI_PHY and ALT_XCVR_RECONFIG megafunctions. I want to check if these functions solve my problem. Does any body know if the ALT_XCVR_RECONFIG are available for Stratix IV?
Are there some ideas about the lane mix up?
Jens
