15 years agoXAUI Phy in Stratix IV GX
Hi, actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started wi...
13 years agoYes, you need the reconfiguration controller because the offset cancellation must be done. Look at my attached screenshots.
They show the settings for the LPMs, which I use actually on a custom hardware. For the devkit it should be the same. The analog options in XAUI Phy may vary. xaui_lpms.jpg show the connection between reconfig controller and phy. The signal reconfig_fromgxb is splitted between the 2 phys. (described in Stratix IV Device Handbook Volume 2: Transceivers, Feb. 2011, p. 5-77) reconfig_clk.jpg shows the constraints for the clock to the reconfig controller. Use an appropriate clock on the devkit. The connection from xgmii_rx_clk to xgmii_tx_clk is correct. I use this clock to drive the control logic for send and receive data over the XAUI channels. I do not use a MAC (10GE) just the low level XAUI protocol. best regards Jens
