15 years agoXAUI Phy in Stratix IV GX
Hi, actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started wi...
15 years agoDave, you are right. The bytes are swapped. Also in some cases the alignment is not correct.
I read in the transceiver section of Stratix IV hadbook that byte ordering is disabled in XAUI mode (refer figure 1-123, page 1-156). Furthermore the rx_enabyteord (together with rx_ byteorderalignstatus) signal is just used when byte ordering block is enabled. In XAUI mode I don't have access to these signals. Even if I had the possibility to restart byte ordering operation how should I know when it is to do? After each reset the byte order is random. In the attached screenshots you see also the misalignment. Affected are also the control signals. Transmit: control | 0xFF | 0x00 lane 3 | 0x0707 | 0xAD00 lane 2 | 0x0707 | 0x0000 lane 1 | 0x0707 | 0x0000 lane 0 | 0x0707 | 0x00AB Receive: control | 0xFF | 0x55 | 0xAA lane 3 | 0x0707 | 0x0007 | 0x07AD lane 2 | 0x0707 | 0x0007 | 0x0700 lane 1 | 0x0707 | 0x0007 | 0x0700 lane 0 | 0x0707 | 0xAB07 | 0x0700 (for more details see signal tap files in the zip archive). Dave, you have an example with XAUI running on the Devkit and loopback adapter? I could compare it with my implementation. Jens Jens
