15 years agoXAUI Phy in Stratix IV GX
Hi, actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started wi...
13 years agoHello Jens,
Could you please share your xaui project? I'm trying to test by using a hsmc loopback and i'm failing on it. Thank you! --- Quote Start --- Hi Nick, Now I'm using XAUI_PHY LPM instead of ALTGX. At the receiver the upper and lower 32 Bits of data and corresponding control bytes are swapped sometimes. Transmit: control: 0xFF, 0xFF, 0x01 data: 0x0707 0707 0707 0707 (tel:0707 0707 0707), 0x0707 0707 0707 0707 (tel:0707 0707 0707), 0x1111 1111 2222 22FB Receive: control: 0x0F, 0x0F, 0x1F data: 0x0707 0707 0707 0707 (tel:0707 0707 0707), 0x0707 0707 0707 0707 (tel:0707 0707 0707), 0x2222 22FB 0707 0707 (tel:0707 0707) In some cases at Receive: control: 0xFF, 0xFF, 0x01 data: 0x0707 0707 0707 0707 (tel:0707 0707 0707), 0x0707 0707 0707 0707 (tel:0707 0707 0707), 0x1111 1111 2222 22FB After Idle-Code Gap I do the alignment manually by means of detecting the START Code (0xFB) in the upper or lower 32 Bit word. Because we are using our own protocol we can do that. I don't know how its viable in case of 10GE. Good Luck! Jens --- Quote End ---
