15 years agoXAUI Phy in Stratix IV GX
Hi, actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started wi...
13 years agoHi comododragon,
I could not find the project on my workstation. It's more than one year gone. Finally the swapping of lower and upper 32 Bits in case the alignment was wrong was the key to bring up the XAUI. Within the project we used the alt2gxb_reconfig and xaui_phy Megafunctions. For the loopback test the best is you have two instances of XAUI Phy. The alt2gxb_reconfig must configured for using two Phys. What are the problems in your case? Jens
