15 years agoXAUI Phy in Stratix IV GX
Hi, actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started wi...
15 years agoHi Jens,
--- Quote Start --- Dave, you are right. The bytes are swapped. Also in some cases the alignment is not correct. --- Quote End --- Ok, so this is a XAUI synchronization issue then. I have not used the XAUI core. --- Quote Start --- After each reset the byte order is random. In the attached screenshots you see also the misalignment. --- Quote End --- I'd recommend putting a Modelsim simulation together. Its a lot easier to probe signals and change things there. --- Quote Start --- Dave, do you have an example with XAUI running on the Devkit and loopback adapter? I could compare it with my implementation. --- Quote End --- I'm sorry, but I do not. Perhaps someone more familiar with the operation of the XAUI core can comment on how the link is supposed to be synchronized. Cheers, Dave
