Video Clock Output to SDI II in Agilex 5
I'm trying to output a video chain using the VVP cores but I can't figure out how to connect the VCO to the SDI II.
on Quartus 18.1, the VCO core would output vid_data[19..0], vid_trs, and vid_ln[10..0] which I would then connect straight to the SDI core.
But i'm now using Quartus 25.3 PRO, VVP 24.1 manual (24.6 according the version readback registers) and its VCO outputs only a AXI4S_fr bus that doesn't have the same signals to connect straight to the SDI II core.
I can't find any examples or documentations on this. The SDI II generate example usings an SDI RX connected to an SDI TX and that doesn't help me.
any help on how to connect hte two cores???
thanks - rob
- Wincent_Altera
Which device that you are targeting ?
From the title , I assume is Agilex 5 right..
IF Agilex 5 , it is using GTS SDI II, instead of older version of SDI II.
For the signal name please refer to https://www.intel.com/content/www/us/en/docs/programmable/823539/25-3/gts-quick-reference.html
Check the similar signal and try to connect accordingly. IF there is no error shown in Quartus then it shall be something valid.
Wincent- aucamera1
Wincent,
in that document you linked, it references a parameter setting "Enable active video data protocols" which is not an option when I try to create the core.
Also, from Section 5.4.3 Intel FPGA Video Streaming Interface:This IP can optionally transport video using the Altera FPGA streaming video protocol,
which uses the industry standard AXI4-Stream protocol with extensions for
transporting metapacket and active video data.
It allows interfacing to Altera FPGA Video and Vision Processing (VVP) Suite IPs or
other AXI4-Stream compliant third-party video IPs.
Note: This feature is only available for Agilex 7 F-Tile device.
So how do we do this with the Agilex 5?
thanks - rob- Wincent_Altera
Hi Rob,
Is there anything else you think I can better assist you ?
Regards,Wincent
- aucamera1
yes, the Agilex 5
yes, i'm using hte GTS SDI II
there are no similar pins. Especially if trying to connect the two cores in Platform Designer.
is there no example of how to use the GTS SDI II with the VVP cores? The two connected seems like it would be the most common use case.thanks
-rob
- Wincent_Altera
Hi Rob,
At the moment, we do not offer direct example to connect it.
My best suggestion is compare both signal name between SDI II IP vs GTS SDI II IP and try it.
The signal function will be pretty much similar , just need to be extra careful to check the signal requirement.
Wincent
