Video Clock Output to SDI II in Agilex 5
yes, the Agilex 5
yes, i'm using hte GTS SDI II
there are no similar pins. Especially if trying to connect the two cores in Platform Designer.
is there no example of how to use the GTS SDI II with the VVP cores? The two connected seems like it would be the most common use case.
thanks
-rob
Hi Rob,
At the moment, we do not offer direct example to connect it.
My best suggestion is compare both signal name between SDI II IP vs GTS SDI II IP and try it.
The signal function will be pretty much similar , just need to be extra careful to check the signal requirement.
Wincent
- aucamera19 months ago
Hi Wincent,
unfortunately, as I stated earlier, there are no similar pins between the two IP cores.
- Wincent_Altera9 months ago
Hi aucamera1 ,
I check with our design team - the VVP for GTS SDI II connection is available in newer release of Quartus v25.3.1.So that features is supported in v25.3.1 for GTS SDI II - Agilex 5.
You just need to create a design based on Agilex 5 OPN number, By right the connection shall be ready there. Let me know if you still no getting it.
Wincent
