14 years ago
[VHDL] integer to std_logic or std_logic_vector conversion
I've some issues to convert integer to std_logic or std_logic_vector.
I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as integer and needs to translate it to std_logic or std_logic_vector.
I can store stimuli as integer but I can't translate it to std_logic or std_logic_vector. I try first to cast them to unsigned and cast after the result to std_logic or std_logic_vector.
I use the ieee.numeric_std package because I read that using the ieee.std_logic_unsigned package could lead to errors (then, i do not use the conv_std_logic_vector function).
Here is an extract of my code.
Please provide any advice or ideas to solve my problem.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE work.txt_util.all;
ENTITY read_conv IS
PORT(
clk : in std_logic;
rst_n : in std_logic;
start_in : in std_logic;
--- std_logic inputs ---
reset_hw_i : in integer;
wdogInitDelay_i : in integer;
--- std_logic outputs ---
reset_hw_o : out std_logic;
wdogInitDelay_o : out std_logic_vector(15 downto 0)
END read_conv;
ARCHITECTURE arch_read_conv OF read_conv IS
BEGIN
conv : PROCESS (clk, rst_n)
VARIABLE reset_hwVar : std_logic;
VARIABLE wdogInitDelayVar : std_logic_vector(15 downto 0);
BEGIN
if rst_n='0' then
reset_hwVar := '0';
reset_hw_o <= '0';
wdogInitDelayVar := (others=>'0');
wdogInitDelay_o <= (others=>'0');
else
-- Cast an integer to an unsigned on 1 bit and cast it again to std_logic
reset_hwVar := std_logic_vector(to_unsigned(reset_hw_i, 1));
print("Integer read : 0x" & str(reset_hw_i, 16));
print("std_logic_vector 0x" & str(reset_hwVar));
reset_hw_o <= reset_hwVar;
-- Cast an integer to an unsigned on 16 bit and cast it again to std_logic_vector
wdogInitDelayVar := std_logic_vector(to_unsigned(wdogInitDelay_i, 16));
print("Integer read : 0x" & str(wdogInitDelay_i, 16));
print("std_logic_vector 0x" & hstr(wdogInitDelayVar));
wdogInitDelay_o <= wdogInitDelayVar;
end if;
END PROCESS conv;
&#12288;
&#12288;
&#12288;
END arch_read_conv;
    Looks like a pretty long thread about a trivial VHDL problem.
    Why don't you simply write a conversion function that returns '0'= for input = 0 otherwise '1'?
    I agree with FvM, a simple conversion function would make more sense to another reader.
    --- Quote Start ---
    wdogInitDelayVar := to_unsigned(wdogInitDelay_i, 16)(15 downto 0);
    --- Quote End ---
    That wont work, because you're trying to assign an unsigned to a std_logic_vector. You need this:
    wdogInitDelayVar := std_logic_vector( to_unsigned(wdogInitDelay_i, 16) );
    There is no problem with this code. If Cadence keeps giving you an error about range constraints, get a better simulator.
    --- Quote Start ---
    --- Quote End ---
    Thanks for the "trivial VHDL problem", I'm trying to solve it for 3 days. :-P
    If you look at the process, I could do it for the integer which is 0 or 1 (reset_hw_i signal), but first it's not a clean solution. I come from Verilog and if there is no way to convert it cleanly, my opinion on VHDL would be quite bad ;-)
    But there are not just a "binary" integer, there is also an unsigned integer (wdogInitDelay_i on 16 bits) and I don't want to code an if statement for the 2^16 converion possibilities :-D
    You have to remember that integers have no individual bits. Hence why they need converting to an unsigned type (which is an array of std_logic).
    You can easily have a range of integer that is 0 or 1 like this:
    subtype int_bool is integer range 0 to 1;
    signal my_very_short_integer : int_bool;
    then an assignment like this:
    my_very_short_integer <= 2;
    will throw an error.
    Indeed, but I need std_logic/std_logic_vector signals because it's the input signal type of my device under test...
    --- Quote Start ---
    --- Quote End ---
    I was just answering your question about why integers were not binary.
    Anyway - thats not a problem, we've said a conversion function isnt really that hard to do:
    function int_to_sl(x : integer) return std_logic is
    begin
      if x > 0 then return '1';
      else return '0';
      end if;
    end function int_to_sl;
    a <= int_to_sl( my_input );
    Ok, I think I'll try a better simulator monday because this one has issues.
    Thank you all for your help, I might come back monday ;-)
    Referring to the said verilog identity of bool, bit and (integer value != 0), I would pefer x /= 0 as an exact VHDL equivalent, because integers can be negative as well.
    The necessity to perform a type conversion is brought up by the strict typification of VHDL. Coming from Verilog, it may be annoying for you, but it serves a purpose.
