14 years ago[VHDL] integer to std_logic or std_logic_vector conversion
Hello, I've some issues to convert integer to std_logic or std_logic_vector. I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as intege...
14 years ago --- Quote Start --- Looks like a pretty long thread about a trivial VHDL problem. Why don't you simply write a conversion function that returns '0'= for input = 0 otherwise '1'? --- Quote End --- Thanks for the "trivial VHDL problem", I'm trying to solve it for 3 days. :-P If you look at the process, I could do it for the integer which is 0 or 1 (reset_hw_i signal), but first it's not a clean solution. I come from Verilog and if there is no way to convert it cleanly, my opinion on VHDL would be quite bad ;-) But there are not just a "binary" integer, there is also an unsigned integer (wdogInitDelay_i on 16 bits) and I don't want to code an if statement for the 2^16 converion possibilities :-D
