14 years ago[VHDL] integer to std_logic or std_logic_vector conversion
Hello, I've some issues to convert integer to std_logic or std_logic_vector. I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as intege...
14 years agoI agree with FvM, a simple conversion function would make more sense to another reader.
--- Quote Start ---
VARIABLE wdogInitDelayVar : std_logic_vector(15 downto 0);
wdogInitDelayVar := to_unsigned(wdogInitDelay_i, 16)(15 downto 0); --- Quote End --- That wont work, because you're trying to assign an unsigned to a std_logic_vector. You need this: wdogInitDelayVar := std_logic_vector( to_unsigned(wdogInitDelay_i, 16) ); There is no problem with this code. If Cadence keeps giving you an error about range constraints, get a better simulator.
