vhdl help
In vhdl can we make an pin declared as "inout" to act as input or as output depending on certain condition. entity rout is port( a : inout bit; b : inout bit; ); end rout; i want "b" to act as output when a is input, and "a" as output when "b" is input. I am using altera quartus 2 9.0 and i am getting this warning. "Warning: The following nodes have both tri-state and non-tri-state drivers Warning: Inserted always-enabled tri-state buffer between "a" and its non-tri-state driver. Warning: Inserted always-enabled tri-state buffer between "b" and its non-tri-state driver." what can i do to overcome this warning. It may sound silly but i am a beginner and i need some help in this regard.17 Replies
thanks ,i'll try
normally, its a problem with your code rather than anything to do with quartus
So do you know some common methods to solve it,like modify quartus settings ,the procedure or both?
Without seeing your code, I cant tell you what the problem is.
My previous 2 reasons are just the most common causes of the "output not dependent on inputs" problem. - Altera_Forum
Nice reply!Thanks!
Actually ,there are warnings about some output pins are stuck at GND this happened maybe when I didnot give their inial values.You know I can't give each value for each of them.so how to prevent them from being stuck at GND or synthesized away? - Altera_Forum
It probably means that any logic you have got in there has been synthesised away. Often this can come from unconnected clocks or enables stuck at '0'
Here is another confusing warning: Warning (15610): No output dependent on input pin "RXD".I have already used it like this "receiver PORT MAP (RXD,...,...); and "RSR<=RXD & RSR(7 DOWNTO 1)".How does this warning come from?
--- Quote Start --- Try and initialise the operands at signal declaration. Simulation tools don't assume an initial value unless it is specified. --- Quote End --- Values left uninitialised always start at the left most value in the declaration. So for std_logic they always start at 'U' sybtype myint is integer range -15 to 27; would initialise to -15. type statemachine is (idle, state1, state2, state3) would start at idle. - Altera_Forum
thanks a lot
