y-fujiwara's avatar
y-fujiwara
1 month ago
Investigation of HIGH-Level Voltage Fluctuations on MAX 10 3.3 V LVTTL Output Signals
We are investigating the cause of fluctuations in the HIGH-level voltage of a 3.3 V LVTTL output signal from the MAX 10 FPGA.
Device Part Number: 10M08DCF256I7G
HIGH-Level Voltage: 2.8 V to 3.3 V
1.Verification of BANK Power Supply Stability
We compared the BANK power supply voltage with the signal voltage and confirmed that the power supply voltage remains stable even when fluctuations occur in the signal voltage.
2.Relationship with the Connected Device (Under Investigation)
Connection: MAX 10 → [3.3 V LVTTL, 8 mA] → DS90CR287
 ・Changing the damping resistor from 22 Ω to 0 Ω did not affect the issue.
Could you please advise us on the possible causes of this issue and any additional aspects we should investigate?
  • FvM's avatar
    FvM
    some additional questions:
    Are you seeing level variations in static voltage (DC or slow signal) or in high level of a pulse waveform (MHz speed)?
    In the latter case, are you sure that it's no measurement artifact, e.g. due to unsuitable probing?
    You say external device is DS90CR287, presume you are feeding CMOS inputs without additional load?
    Regards Frank
    • y-fujiwara's avatar
      y-fujiwara
      1. The issue is a variation in the high-level voltage of a pulse signal in the 1 MHz range.
      2. An active probe is used, with the GND connection made through the shortest possible via.
      3. No additional load is applied.
      We also confirmed with TI that noise from the LVDS signal may couple through the IC's internal circuitry.
      Since this phenomenon has not been observed on signals connected to other devices, we believe this is the likely cause.
      • AqidAyman_Altera's avatar
        AqidAyman_Altera
        May I know what is your main concern on this voltage fluctuations?
        I checked the datasheet of the external device you connected and found that 2.8 V is still a valid high for the DS90CR287. The TxIN pins are LVTTL/LVCMOS inputs, and the datasheet specifies VIH at 2.0 V minimum (DS90CR287, SNLS056, https://www.ti.com/lit/ds/symlink/ds90cr287.pdf). Correct me if I'm wrong.
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
