16 years agovhdl help
Hi, In vhdl can we make an pin declared as "inout" to act as input or as output depending on certain condition. entity rout is port( a : inout bit; b : inout bit; );...
16 years agoWithout seeing your code, I cant tell you what the problem is.
My previous 2 reasons are just the most common causes of the "output not dependent on inputs" problem.
