16 years agovhdl help
Hi, In vhdl can we make an pin declared as "inout" to act as input or as output depending on certain condition. entity rout is port( a : inout bit; b : inout bit; );...
16 years ago --- Quote Start --- Try and initialise the operands at signal declaration. Simulation tools don't assume an initial value unless it is specified. --- Quote End --- Values left uninitialised always start at the left most value in the declaration. So for std_logic they always start at 'U' sybtype myint is integer range -15 to 27; would initialise to -15. type statemachine is (idle, state1, state2, state3) would start at idle.
