15 years agousing lvds
G´day !!
I´m using an ADC with differential output (LVDS). It´s a device including 8 ADCs with Serial LVDS output. Data from each ADC is serialized and provided on a seperate channel. This serial data (data rate for each serial stream is 700Mbps maximum) is read with Cyclon III. What´s the best way to do this ? I found the ALTLVDS Megafunction, but i think this block has no sense, cause of the serialization factor of 1 for each channel used in my system. But what´s the best way to read and process the sampled input data ?? Is it possible to wire this LVDS Serial data direct to a PIO ??? hope someone can help me greets !!!45 Replies
TYPE RXTYPE IS ARRAY (0 to 3) of STD_LOGIC_VECTOR(13 downto 0); SIGNAL lvds_rx : RXTYPE; SIGNAL lvds_sr : RXTYPE; - Altera_Forum
ok, i´m glad i´ve the same, but how do u write to an out port as effectively as possible ?
--- Quote Start --- how do u write to an out port as effectively as possible ? --- Quote End --- Effectively in what regard? And which outport? - Altera_Forum
i just thought in giving out the result vektor (parallelized sampled data) on an output port...
TO_BE_DONE
I didn't yet observe the reported warning and don't know why it's generated in your design. May be it's due to the ad_in2_tmp wire signal.
Actually Cyclone IV uses LE registers for ddio_in, so the warning is irrelevant in any case. You should primarly look for succesful timing closure and first of all correct operation of actual hardware design. - Altera_Forum
--- Quote Start --- I didn't yet observe the reported warning and don't know why it's generated in your design. May be it's due to the ad_in2_tmp wire signal. Actually Cyclone IV uses LE registers for ddio_in, so the warning is irrelevant in any case. You should primarly look for succesful timing closure and first of all correct operation of actual hardware design. --- Quote End --- Thx for ur reply. Shortly, I have two questions as follow:- Could the input of ALTDDIO_IN connect the I/O input signal directly? Or the input of ALTDDIO_IN should connect particular I/O pin? When I connect I/O pin to ALTDDIO_IN directly, I got the following Warning.
Warning (176225): Can't pack node ad_ddio_in:inst_ad_ddio_in|altddio_in:ALTDDIO_IN_component|ddio_in_1di:auto_generated|input_cell_l to I/O pin - I don't know if I should source synchronize the AD data clock(DCO) and the AD output(ad_in2). If I use a PLL to creat a clock(dco_clk) in source synchronous mode, I should do PLL compensation in Assignment Editor, or I will get this warning.
So I added the following codes and the above warning dispears.Warning (15062): PLL "ad_pll:inst_ad_pll|altpll:altpll_component|ad_pll_altpll:auto_generated|pll1" in Source Synchronous mode with compensated output clock set to clk is not fully compensated because it does not feed an I/O input register
But in this way, I can only get the partial data of (ad_in2) because it's DDR output. So I don't know what should I do to figure this out.Could u give me some suggestions plz?process(dco_clk) begin if(rising_edge(dco_clk)) then ad_in2_reg <= ad_in2; end if; end process;
--- Quote Start --- However as the outputs of the ADC are nicely source synchronous and are accompanied by a dataclock and a frame-indicator , you can easily deserialise the ADC data channels with simple shiftregisters. Feed the inputs into a DDR-In block and then serialise the 2 bits in a 7-bit shiftregister each. assemble the 2 7-bit buses into a 14-bit bus and define the right moment to register it. You need to do some work to constrain all this though. I have done this for ADS527x and AD9222 octal ADCs, unfortunately my code is in AHDL (I do use VHDL nowadays). --- Quote End --- Hi josyb, I'm using an AD9252 pretty similar with AD9222. I have a question about what u said above. Did ur AD output connect with the input of DDR-in block directly? When connecting directly, I got 2 Warnings like this.
And the messages of Ignored Assignments are as follows.Warning (176225): Can't pack node ad_ddio_in:inst_ad_ddio_in|altddio_in:ALTDDIO_IN_component|ddio_in_1di:auto_generated|input_cell_l to I/O pin Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
I don't know how to solve this problem. Could u give me some suggestions? And, should the AD outputs connect some particular I/O pins? The FPGA I'm using is EP4CE115F29. Many thanks!Name: DDIO_INPUT_REGISTER Ignored Entity:altddio_in Ignored From: Ignored To:input_cell_H Ignored Value:HIGH Ignored Source:Compiler or HDL Assignment Name: DDIO_INPUT_REGISTER Ignored Entity:altddio_in Ignored From: Ignored To:input_cell_L Ignored Value:LOW Ignored Source:Compiler or HDL Assignment - Altera_Forum
--- Quote Start --- I didn't yet observe the reported warning and don't know why it's generated in your design. May be it's due to the ad_in2_tmp wire signal. Actually Cyclone IV uses LE registers for ddio_in, so the warning is irrelevant in any case. You should primarly look for succesful timing closure and first of all correct operation of actual hardware design. --- Quote End --- Cyclone IV uses LE registers for ddio_in, but it seems that the input of ddio_in cannot connect I/O pin directly, right? - Altera_Forum
--- Quote Start --- The serialisation factor in your system is actually 14. The ALTLVDS does not support this, but you could set it to handle a deserialisation of 7 bits and concatenate two 7-bit packets into one 14 bit. ALTLVDS however uses a PLL to sample the inputs, so if you have multiple devices, ADCs in this case) you may run out of PLLs. However as the outputs of the ADC are nicely source synchronous and are accompanied by a dataclock and a frame-indicator , you can easily deserialise the ADC data channels with simple shiftregisters. Feed the inputs into a DDR-In block and then serialise the 2 bits in a 7-bit shiftregister each. assemble the 2 7-bit buses into a 14-bit bus and define the right moment to register it. You need to do some work to constrain all this though. I have done this for ADS527x and AD9222 octal ADCs, unfortunately my code is in AHDL (I do use VHDL nowadays). --- Quote End --- I changed a way of using the ADC data clock and AD output to connect the inputs of DDR-In block directly(without PLL source synchronous mode), and there is also an invalid Fitter assignments as follows and I don't know why.
Although the above invalid Fitter assignment Warning appears, but I can find the ALTDDIO_IN module in the Technology Map Viewer. So does it mean that the above warning has no effect on the implementation of its function?Name: DDIO_INPUT_REGISTER Ignored Entity:altddio_in Ignored From: Ignored To:input_cell_H Ignored Value:HIGH Ignored Source:Compiler or HDL Assignment Name: DDIO_INPUT_REGISTER Ignored Entity:altddio_in Ignored From: Ignored To:input_cell_L Ignored Value:LOW Ignored Source:Compiler or HDL Assignment
